Form 3 Unboxing and First Impressions!
#105
Mine arrived yesterday but I’m more in the mood to sit tight til extra vats and resin arrive before putting it through its paces. Interestingly, the US store indicates a 3-week lead time on Form 3 Vats, but the order placed a week ago claims to be shipping soon.
#106
I received my printer about a week ago testing everything I could before I gave any kind of review. Honestly I don’t really know what to say about it. I’m not getting the same kind of vibes as I did when I got the form2 as it sort of magically printed everything I threw at it, rather, I come here to read that the 50 microns setting is having anomalies which explains so much as I’ve been having inconsistent success of the prints with no changes to the file.
The silence may be just giving formlabs time to update its software which I hope is the root cause towards all the pains of figuring out the machine, which as of right now, I would say is objectively worse than the form 2 in terms of actual print-ability. It feels as though the printer was rushed out with half-baked optimization which probably needed 6-12 months worth of fine-tuning. I really don’t have anything bad to say about the hardware itself as I feel it’s indeed an upgrade but unsure about the tray.
I specifically work on miniatures and unfortunately i’m getting lower quality prints from the 25 micron setting on the form 3 than the 50 micron setting on the form 2. It’s the same problems people have talked about before of the prints details being softer and losing it’s definition in comparison to the form 2. For this part I don’t know if it’s because of the film from the tray or the resin no longer being optimized for the form 3 or simply needing more time in testing on the firmware.
I agree with about every point that Kenneth put down minus the print quality and loudness problems. Overall, I can see the machine being great but it feels like it was released way too early hence why even the 2 or so months delay in delivery.
#107
**About time! Thank you for an actual end user review with experience on previous models. This post is very informative and confirmed my suspicions about the form 3. Thank you again for taking the time to post this info.
#108
I’ll chime in with a few brief first impressions of my Form 3:
Out of the box experience was pretty good. Setup was a breeze, and Formlabs went overboard on the warnings to make sure the LPU screws are removed before using the printer. The warning stickers on the printer tore and left residue when I pulled them off, but that’s just a minor annoyance. The touchscreen works great and the UI is intuitive. I hope a future firmware update will disable the fan noise while not in use.
Fit and finish leaves a bit to be desired. The bottom chassis cover on the front appears to be warped, and the exterior is now entirely plastic instead of the nice anodized aluminum on previous printers. The industrial design seems a bit strange to me with odd curves and angles. However, what matters is on the inside, and it’s obvious this is a much more complex printer with a lot going on. Time will tell if the additional sensors and complexity have contributed a better and more reliable printer.
The new resin tanks seem great. I like the included storage container.
I’ve only done 3 prints so far (White V4), but the print quality has been underwhelming to say the least. I was expecting to see a jump in quality similar to what I experienced going from the Form 1+ to the Form 2, but sadly it feels like taking a step back. White V4 is probably not the best resin to evaluate the print quality with, but right now I’m kind of wishing I still had my Form 2. I’m sure that, over time, firmware updates and new resin formulations will unlock the true potential of the Form 3.
#109
Okay, so yeasterday the replacement printer showed up. The box overall looked fine except one corner had s mild hit… nothing different than typical shipping wear. Just a mild crush. I took the printer out of the box and noticed it wobbled quite a bit after placing it on my office desk. I looked at the legs and they were all screwed in so I’m not sure why I had a wobble of over 1/2" movement. Then I saw on the right rear side that the rear plastic cover was out and not seated under the rear of the side of the aluminum. This clearly was damage either due to shipping to Formlabs or from Formlabs. I didn’t even get as far as removing the shipping stickers. Another very upsetting thing to see was the amount of dirt inside the machine. Either this was not a new replacement or it’s cover was open and dust and dirt accumulated inside.
Needless to say, I sent a video and pics into Formlabs and waiting on their response on how to proceed. I also received, as I’m sure everyone else did, a formal email from Formlabs stating that the 3 most important resins that truly matter and used by most of us are formally not compatible with the Form 3 and they have stated their is not set time to rectify the situation. For those that purchased the 3, they should have received a coupon code for a free liter of any resin that will work with the 3.
Review: Form 3 is not better than the Form 2 with respect to, and only to the following key points that matter to end users… build size, print quality, print speed, and resin selection. Newer tech… yes. But, what does the 3 have over the 2? In my opinion, you are taking a step back. People are saying the quality is better. I won’t get into any discussions other than… I saw no difference in print quality between the two machines at any layer height. However, I saw significant print time added to builds vs the Form 2. Significant by several hours. I saw print anomalies and print shifts across a range of small to large prints. I agree with Joxol… the printer was released way too soon. I know Formlabs knows they released a printer before finalizing important things like… resin compatibility. No way they didn’t know. I was told early on that they hoped to work all know issues with software updates or resin adjustments. Seeing a coupon code being handed out and a formal statement that they have no set time to fix the issues is not a good sign.
My advice… keep supporting the Form 2. I ran 2 form 2s non stop through two seasons of Altered Carbon on Netflix, Deadpool 2, Skyscraper and a couple others and they performed flawlessly! I had no (ZERO) fails. The only fails I had were when I tried to push the machines to do something I already knew it wouldn’t. The Form 2 is (in every point important to end users. Build envelope, print times, print quality, and reliability) better than the Form 3. Knowing this… how can I justify making a business decision to purchase a Form 3L.
There ya go guys… my honest review of the Form 3. No embellishments or fabrications… just my honest experiences with this machine. Do not purchase this machine unless your intent is to help fund Formlabs financially to work out the issues. If you want a reliable printer with faster speeds, better print quality, and the same build envelope as the 3 (which actually is the same as the 2 I should say. lol), then do yourself a favor and just buy a 2. To all you guys that have 3s and love them, I ask you… did you have a 2 first? If you did, you either didn’t do an actual print comparson between the two machines using the same print file with no changes or… you got extremely lucky with your Form 3 printer and I’m jealous for that. lol
#110
I’ve been using my Form3 for about a week. Print quality compared to my Form2 is the same but some of the issues I get with the form2 are not present in my Form3 prints. For example, around half of my Form2 prints (with a new tank and resin cartridge) will end up with some coagulated resin between supports close to the print. It will print with a support adhered to the print along the entire stem of the support instead of printing with a space. In this case, the support is generally for an overhang.
The Form3 is in my experience, 30% slower than the Form2. My first prints failed, in part because for as yet unexplained reasons, part of it detached and the print just kept building upon the tank. The second failed because it would NOT come off the platform. I ended up breaking the print and gauging the platform just to remove it and this was after an overnight soak in IPA.
Using my Form2 platform, subsequent prints have at least come away from the platform.
The Form3 is LOUD. I did the firmware update but it is still LOUD. That’s ok, I don’t care so long as prints are perfect and without issues. It also smells more, perhaps due to the change in how the chamber is heated vs the Form2 heating method.
Over all…I’m undecided.
That $500 credit towards consumables, anyone actually get that???
#111
Quick update on my impressions after a few more weeks:
Form 3 is definitely smellier than the Form 2, but I don’t mind it too much.
Being able to prime the printer for remote start of prints is awesome. I do it every time.
Other than the disappointing print quality, I’m having print failures with normal rafts. The first mm or two of the raft prints fine, and then the rest gets stuck to the bottom of the resin tank.
#112
I have done 67 prints on Form 3 and have no complaints about print quality. It is superior to my two Form 2’s especially on Draft (huge difference) but also on white, grey, and flexible resins. I have had no print failures that weren’t egregious errors on the support design side, I typically use smaller supports on Form 3 in fact. Importantly, my Form 2 machines have been in operation for at least a year so they are a bit worn (we run three printers almost 24/5).
In terms of print speed, I haven’t done a proper comparison. I don’t think it is fair to just look at the estimated time because the Form 2 massively underestimates actual print time.
Noise or smell doesn’t matter to us.
#113
Unless you have the golden printer, I can’t help but find this post disingenuous as it smacks of “fan-boy” language.
I say this emphatically because the smell is a physical fact. It can’t be on one without being on all, as all use the same heating methods and its that method which is a direct contributor to the odors. Now granted, you could be using 3rd party resins if you are re-using spent cartridges to trick the printer but I doubt this is the case.
Secondly, it is slower. Formlabs admits this and again, it is a characteristic of the printer tied to software they all share, yous can’t be faster unless you have a special firmware, again —very unlikely.
My Form2 printers (all of them that I have had) have printed within 10% of the stated time. My Form3, like others that have posted on the subject, is outside of 30%.
Next I bet you want to tell us your Form3 whistles Dixie while printing as it serves you a macchiato.
#114
I’ve completed my first print with my new form 3. I’ve got no previous Form experience - what printing I have done has been FDM (and not a lot of it).
It’s only one print, of course, but that print went entirely to plan. The time estimate was within about 15 minutes of the actual print time (of a bit more than 12 hours). I don’t think the printer is “noisy.” I don’t have much to compare it to. The Form Wash is substantially louder than the printer (but not in an abnormal or unexpected way).
The print tore away from the supports in a manner that was substantially similar to the video Form shows of tearing a printed case piece off a tree of supports with just one hand and a wrenching movement. The result for me was some internal supports left behind, but a substantially completed print with good surface finish. My engraved lettering did not come through (1/32" depth in a 1/16" thick wall), but perhaps I need to iterate on my design.
If I have anything to complain about, it’s that after printing and a trip through the wash, the print still seems tacky and unfinished (I don’t think this is 3 specific, of course). I don’t have a Form Cure, but I do have a UV source. I’m going to try irradiating it for a while to see if a combination of a bit of UV and just letting the IPA evaporate will finish the print properly. Then I’ll assemble the print the rest of the way and post a picture of the result.
The dashboard doesn’t do a great job on reporting status when a job is near completion it sort of prematurely says it’s done, but if you refresh the page it’s still at 90+%. However, I did get the SMS notification at the point where the job actually finished.
Meanwhile, the printer is back at work on the next thing.
#115
Some pictures from the second print, which is somewhat more interesting. It’s a button.
#116
A 12 hour print and it printed with 15 minutes of the stated time?
You have a golden printer too!
I have a real world printer. The exact same .form file, changed only to add supports applicable to the Form2 and the Form3 while retaining orientation and location. Same print level of .1 in the same resin, standard grey v4 and both started at the exact same time. The Form2 printed over three hours sooner. Total print time for the Form3 was 9 hours and the Form2 was 5 hours and 38 minutes.
#117
I didn’t say it printed in the same time as a Form 2. I don’t have and have never used one, so I can’t make that comparison.
I’ve printed a half dozen more things since I posted and the time estimates from Preform have been equally as accurate. I’ve printed exclusively at 100 microns so far. All I can say is that my experience thus far differs from your stated experience.
#118
Dearest Zenica,
For every fanboy there is a hater I guess. I find your post completely useless (my opinion, not a fact).
Smell and noise disruption is definitely an opinion/preference. I don’t care about the smell because our lab reeks of pig guts and IPA. I don’t care about the noise because it is in an area with music and talking and other machinery. I didn’t say there was no smell, learn to read. I said it doesn’t matter to us.
So you have timed every single one of your prints and have never had a resin warning, any other error, differences in heat up time, or anything and they are all within 10%? You must have the golden Form 2 since mine does this very frequently. I also never said it was faster, please do us all a favor and read thoroughly.
The noise my Form 3 makes actually does sound like Dixie!! I don’t drink coffee though, only the tears of haters.
#119
You may want to take a course in “Reading and Comprehension”, I was merely pointing out the smell is there, irrespective to whether or not you care about inhaling a VOC.
My Form2 has been anything but golden. I had several replacements in the year it was purchased and the inference from discussing the relationship of time to print across the latest two models is to exclude outliers and anomalous prints, such as failures. That said, yes, all of my Form2 successful prints have occurred within 10% when aggregated across all prints. You brought up speed when you stated “Form 2 massively underestimates actual print time.” and then cavalierly implied the Form3 is equal to the Form2 in print speed when you said " I don’t think it is fair to just look at the estimated time" which by the way isn’t reflective of what I and others have based the time on. In my case, the time is based on how long the print took.
#120
Hey there @nsayer! Do you mind if I ask what concentration of IPA you’re using in the wash is, and whether it’s fresh IPA?
The most common cause of a tacky part after washing is IPA of a lower than optimal concentration, either through the alcohol % of the IPA itself or because it’s a little dirty.
#121
I started with brand new 95% IPA. If I look at it 8 prints in, it has a white cast to it (I have white resin), but the hydrometer still says it’s "new"ish.
I’ve sprung for a Cure. Maybe it’ll make the difference,
#122
If you have a sticky texture, then try submerging the print in water and cure it for a few minutes that way. Oxygen prevents the resin from curing to some degree so submerging it in water blocks the oxygen and the outside can cure more easily, and it only takes a small amount of time. Be careful though, if you cure one side for too long then that side will end up with a lighter sun-bleached kind of look.
#123
I just took delivery today of a Cure, so we’ll see if that makes a difference (I can’t imagine it won’t).
#124
Plus it opens up the possibility of using engineering resins which would have been problematic otherwise.
