Form 1 / 1+ / 2 3rd Party Resin Settings Master List
#537
@David_Persuhn
Thank you. I fully agree.
There are still people using the ‘old’ device I made. They simply are not updating their form 2 anymore. There is no need really as all these 3rd party resins work perfectly on standard clear or grey V2 and V3 settings and the engineering resin which are mainly driving the updates are not really needed. After 2(I think?) year the form 2 is pretty bug free and runs fine.
Regarding the latest solution:
I wanted to let you all know that after a few months of work and testing by several people on the forum(thank you!), the modules are ready and I have them available for shipping right now.
They work great. I tested them with Photocentric 3D resin and others with ALW resins. Printing quality is much better and more accurate than in open mode.
Contact me for details: [email protected]
#538
This topic seems to be getting quiet. :frowning:
Did anyone do any more testing with 3rd party resins? There seem to be a lot of new resin manufacturers popping up the recent months. I’m still looking for a high temp resin that can withstand about 160 C and isn’t a brittle as formlabs’s resin but more close to a material like PBT, PPA, etc.
#539
I’m interested in your 3rd party resin solution @fantasy2. I sent you a message via email.
#540
Wow. I’ve been way out of the loop here for quite a while. Just binge-consumed this entire thread! Some really amazing work by everyone here. My hat is off to everyone but the hubristic douche that @David_Persuhn so eloquently pointed out :slight_smile:
Cheers Lads,
-C
#541
Hehe yeah, I think this is the longest thread so far. :slight_smile:
If someone has the time, it would be interesting to update the list with the new resin manufacturers and improved resins for anyone new joining the party. A lot changed since this thread started!
It’s funny now that since I have a few bottles of cheaper resin, I print every custom small knob and whistle I need for private use without having to think about cost. Some resins are not as smooth or perfect as formlabs resin but you don’t always need that for hobby parts.
#542
Hi all
Just to let you know that we have reformulated all our standard 3Dresyns, including our basic, special and custom RAL and NCS colors, to print directly in open mode with the settings for Formlabs Clear version 2.
We have fine tuned our 3Dresyns to work well with both, the first produced Form 2 printers as well as with last generation ones. We have done the tests with several Form 2 printers bought at different times.
The reformulation has been done because we observed that the optimum dosage of our Fine Tuners FT1 and LB1 varied a bit from one Form 2 printer to another, depending probably on the printer´s manufacturing date and software version. This printability variation with the Form 2 printers and software has been already discussed in the forums.
We have launched several interesting materials, including 3Dresyns with excellent temperature and chemical resistance without brittleness, some ultra safe monomer free resins, engineering functional materials, flexible and elastic materials foldable without breaking, etc,… Our new high deflection temperature resin is rigid and non brittle and resist temperature up to 290C.
Greetings
John M.
3Dresyns
#543
John,
Has there been any testing using your high deflection temperature resin for injection molding?
I am thinking of trying it as the HT resin from form labs works good but its a bit brittle.
Just ordered some for testing :slight_smile:
#544
One thing that I’ve found for injection molding is to mount the detail in the mold frame along with two part silicone (use mold release to keep it from sticking).
The silicone takes up any small gaps and helps keep the detail from cracking.
#545
So I tried the 3DResyn UHT HTR with black pigment today.
Using the recommended clear V2 profile, I had massive under curing and parts breaking partially during printing. Then I did a 30 minute cure in the form Cure and followed by putting them in the oven at 150 Celsius.
The material became extremely brittle at this temperature. Standard formlabs resin performs much better. I’m not sure what’s going wrong here, but so far it’s no better than the photocentric high tensile resin.
I’m now trying to print with it in closed mode. Will do more printing tests and let you know.
#546
FredB,
Thanks for the tip. I do use 100% silicone oil to dress the mold and then anneal to re leave stress.
I have had great success with my first test run. 2 part clip mold
using Hylon @550F (287 C)
FLIR0023
& got 373 shots off it before parts were unusable. I pushed it hard at the end.
#547
Well that’s sad to hear.
Hopefully I have better luck with it.
#548
That’s actually quite a few shots for a printed mold especially if you were pushing things a little.
I’ve used a fan to give extra mold cooling in the past. Takes forever to cool things off.
#549
It was a good first trial. I was hoping for 10 to 50… Cooling takes up a lot of the time. I found that a 15 sec compressed air blast worked great every other shot to keep temp down but keep in mind I was pushing the temp limit of the Hi-temp resin with this material. Toward the end I was pushing 5 shots in a row with mold release every shot then cool for 30 secs. (That’s where I did a lot of the damage) I have made a air gun with a split off to blast each half of the mold at the same time to cut cooling time in half. My end thought would be to design a EOA (end of arm) to automate the cooling and spraying of the molds but this is a ways down the line. I will be running my 2nd test with much lower temps (polyp) and expect to see even more shots.
#550
Well got my order in today of 3dresyns high deflection temperature resin. Very disappointed that the resin came in like sand and is unusable.
#551
@fantasy2 I’m having an issue with your cartridge module. I sent you an email and PM a week ago, is there a better contact for you?
I’ve been using DigitalForge3d resin. I’ve printed maybe half a liter and it’s great. Not a single issue with prints and the price is awesome. So far I’ve been using it in closed mode by pouring it into an empty cartridge. I have not tried it in open mode, but hopefully when I get @fantasy2’s cartridge module working, I won’t ever have to. I’ll post some pics of my next print batch.
#552
Oh wow, it completely dried up?!
Nice to hear! Very cheap resin indeed. I’ve sent you an email, please check it.
#553
Hi Dave
I have just read your post in the Formlabs forum. I am disappointed because you wrote a negative post without giving us any chance nor time to answer your email from yesterday 18/10/2018. We received your email yesterday at 8 pm European time. I am answering now in the morning…
You wrote a complaint in the forum at the same time as you sent us an email, not giving us any chance of explaining how the product has to be handled.
3Dresyn HDT1 is a liquid which tends to solidify naturally after one day or so. This is due to its intrinsic chemical nature. It has a incredibly high Tg. It tends to crystallise naturally before polymerisation. This process is 100% reversible since the material has not polymerised nor become solid and unusable.
It is 100% usable and ready to print. It just needs a gentle warming in the microwave or in a water bath to become liquid again. Once liquid has low viscosity and it is incredibly rigid even at very high temperature.
Best regards
John M.
3Dresyns
#554
My apologizes but this should be something you tell a customer or at least give a heads up on the bottle If it starts to solidify after 1 day! and if there is a process that needs to happen before it is usable then this to should be on the bottle so reviews like this doesn’t happen. ( I see you added a note on your website or maybe I missed it ) A gentle warming in a microwave? Do you any perimeters for reheating in the microwave? I don’t want to degrade it by over heating. If this sits in my tray for more then a day is it going to solidify in my tray during storage? I can’t microwave the tray as theirs metal in it & in open mode the tray will not heat. I must say I am discouraged at the lack of up front info. I have heard a lot of good things about 3dresyns. I will think about if i even want to try using this resin now as I don’t want to risk ruining it before i get to even print with it as it is a pricey resin. I will wait for your reply.
#555
Hi Dave
I accept your apologies. Next time, please wait for our reply before writing a negative post.
As corrective action, to avoid this happens again with another customer we will add a note on the label saying: “warm it gently until melting before using” or we will send an email to the customer with detailed usage instructions, besides the technical information already published in our website www.3dresyns.com and specifically in https://www.3dresyns.com/pages/3dresyn-hdt1
3Dresyn HDT1 has to be warmed up gently in a microwave or even better in a water bath at around 60C until the solid melts and becomes liquid. If you choose to melt in the microwave (put the tap to the bottle to avoid the light of the microwave starts the photopolymerization reaction) please do it gently in steps of 30-45 seconds and shake it, then repeat the process until full melting of the product. After printing, transfer the resin left in the resin tank back to the original bottle. The material will not degrade if it is heated at 60C. Be careful with exposing it to room light since it will react with light as any SLA DLP 3D resin.
I would like to encourage you test it and value its extremely high deflection temperature (rigidity) at room and even very high temperature. Once polymerised in the printer, its softening point and deflection temperature is around 290C, just below 300C.
Remember to print it in open mode in Formlabs clear version 2 settings. All our standard resins have been fine tuned to these settings.
For more detailed instructions we can communicate privately by email or by phone. Please use this contact email as contact: [email protected]
Greetings
John M.
3Dresyns
#556
Hi!
I would like to ask, if someone has succeeded with UV Photocentric Hard Cear resin ?
My Form 1+ printer flawlessly the Maker’s Muse Snowflake Latt in 0.1mm layer height and Clear V4 settings, but I wanted to print with lower layer height and I cannot succeed… (tryed Grey V4 and Clear V4 again)
I’m looking forward to response
Thank you
Lukas
