Where can I get a matching set of the plastic containers that come with the finishing kit?
Hmmm, that’s not something that we sell separately, but any regular set of sealable plastic containers should work fine, I believe.
I know, I was wondering the make and model so I can Google some.
Target has containers that go by the name “snapware” I think that is your closes bet. I think im going to switch to some cheap zip lock brand trow aways…
Thanks Kuhns, I don’t see one the dimensions of the built area, but I will continue the hunt and your info should help. I am setting up for electro-plating and want the dimensions of the build area, but without the expense of filling over-sized containers with expensive chemicals. I’m not sure why Sam did not say.
The build area is 125 mm x 125 mm x 165 mm.
I’d suggest getting a container that is 15-25 mm larger on each side for some buffer.
Yes Craig, but the only place I have ever seen a food container anywhere close to that is from FormLabs.
I settled on MainStays Model# MS044-440-01-29. It took a lot of time to find that.
That’s a great find, Josh. Thanks. I’m sorry that I don’t have the information to find the individual components of our finish kit – they’re acquired through wholesale channels.
