I am reaching out regarding an issue in PreForm that significantly complicates version control during my daily workflow.
Description of the Problem:
When I replace an existing model on the build platform using the “Update” (or replace) function with a newer version (e.g., a new STL file with a new filename like Part_v2.stl instead of Part_v1.stl), the old filename remains completely unchanged in the Model List on the left side.
Why this is an issue:
While it makes sense that the overarching Print Job Name is kept to avoid breaking queues, the fact that the individual object name in the Model List does not update causes a lot of confusion. It makes it very easy to lose track of which iteration or file version is actually loaded on the platform. Manually renaming the model via F2 every time I swap a file is tedious and prone to errors.
My Suggestion / Feature Request:
Please implement a logic (or an option in the preferences) that allows PreForm to automatically update the name in the Model List to the actual filename of the newly loaded STL/OBJ file when a geometry is replaced.
I’ve attached a short screen recording demonstrating the issue.
In this example, the filename shown in the Model List is incomplete after updating the model.
However, I’ve also experienced other cases where the original filename remains completely unchanged after replacing the model.
So the behaviour varies, but the underlying issue is always the same: the Model List does not reliably reflect the filename of the updated geometry.
I hope the recording helps your team investigate this.
Best regards,
Alex
P.S.: One additional detail I forgot to mention: The issue occurs regardless of the file format used when replacing a model. I’ve experienced it with different combinations of FORM, STEP and STL files, so it doesn’t seem to be related to a specific file format or combination.
