# Experimenting with a test resin heater
**URL:** <https://forum.formlabs.com/t/experimenting-with-a-test-resin-heater/6586>\
**Category:** Projects & Prints\
**Created:** [October 20, 2015, 1:38pm UTC](https://forum.formlabs.com/t/experimenting-with-a-test-resin-heater/6586 "2015-10-20T13:38:54Z")\
**Showing post:** 1
**Author:** ![ChristopherBarr](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.formlabs.com/christopherbarr/32/645_2.png) [@ChristopherBarr](https://forum.formlabs.com/u/ChristopherBarr)\
**Post date:** [October 20, 2015, 1:38pm UTC](https://forum.formlabs.com/t/experimenting-with-a-test-resin-heater/6586/1 "2015-10-20T13:38:54Z")
I’m building a test resin heater to see if that will help tough resin prints. I just got a bottle of tough, have yet to try it, but from all I’ve read, it’s viscosity can make it difficult to use. warming it up should help with that. I saw how someong before used a chicken coop heater, which was neat, but I wanted to avoid heating everything with forced air, focusing instead on just heating the resin.
This technique uses a reptile terrarium heating wire (submerged) and a temp control w/ thermocouple. I designed and printed a simple clip to hold the wire as it wraps around in the inside walls of the tank. If this clip does not work very good, I’ve taken a tank lid, cut out the top center so it can be on the tank when printing, and will attach wire holders to the underside of the lid. I wanted a 100% printed and no-fabrication method though, so others could do it easily too if it works good. it may prove to be too messy, but I’m going to try it out anyway. I’ll let you know how it works.
 ![](https://us1.discourse-cdn.com/flex025/uploads/formlabs/original/2X/2/29b4f1be29f5ab51299213d1c94889a8183d8401.jpg)
First test
 ![](https://us1.discourse-cdn.com/flex025/uploads/formlabs/original/2X/0/00756704a099398cd5700a87d72e3f724bd58ec9.jpg)
With clips
 ![](https://us1.discourse-cdn.com/flex025/uploads/formlabs/original/2X/4/4765b002e127a947ef883aa975d0e29461d345e9.jpg)
another shot of clips
 ![](https://us1.discourse-cdn.com/flex025/uploads/formlabs/original/2X/5/5660b093d26e1d3ba75612ff56a2e52cf0932618.jpg)
A jigsaw upside down in a vice makes a nice scroll saw 😄
 ![](https://us1.discourse-cdn.com/flex025/uploads/formlabs/original/2X/8/8546b6964d323ccecf8b92f1d7fce6985b466a8d.jpg)
lid w/ center removed tested during print
Thoughts?
_[View the full topic](https://forum.formlabs.com/t/experimenting-with-a-test-resin-heater/6586)._
