Elastic 50A Resin Tear Repair
#1
Hello,
I am using Elastic 50A Resin for a project and we need to place holes in the printed model, but if the model is pulled at all, the hole rips throughout the entire print. Is there a way to strengthen around the hole so it doesn’t tear or a way to repair the tears so the print is useable?
Thanks!
#2
You can repair a torn or fractured print by applying a little resin to the seam, holding it together, and exposing to UV. I am in fact repairing a busted print this exact way right now.
As for strengthening around the holes, you’ll have to post some pictures, your description isn’t good enough to make any meaningful suggestions…
#3
Does the resin really help? Thanks for the advice, I’ll try it and tell you my progress.
