Does anyone know why the supports when using draft resin would be thin and frail? Many times when I print a part that fills up the entire build volume of the form 2, the supports are sort of failing near the top of the part. Thanks!
Hi @ottocentric,
That sounds like there might be some optical contamination or an issue with the one of the consumables; if you could please open a ticket with our Support Team and send over any relevant photos and .form files, we can take a closer look and help you get this problem resolved!
