Difference in quality between two of the same part
I have a newer resin tank with only a couple parts printed so far so cloudiness should not be an issue. For this print the one in the front/wiper side came out much lower quality with ridges on the surface and the other one looks great. What can cause this?
That’s certainly not something we’d expect - can you upload some pictures?
There are a few things that you might look into. Filtering the tank is always a great first step for issues like this. Can you also check the optical window itself (beneath the tank) to ensure that there isn’t any clouding or hazing there? Shining a light helps to highlight any potential problem areas.
I don’t think filtering would help because this is relatively new tank. I don’t see any cured bits in the resin, cloudyness in the tank or the window either.
