Curing droop
Hi there.
I’m lucky enough to have the Form Cure, which speeds up the curing process lovely. However the extra heat needed to speed up the cure causes drop over long items. With the kind of things I’m printing it’s not always possible to keep all the supports in place when getting them off the plate.
How have others combated this problem? Today I’ve ordered a couple of science glass blocks that I could lie things flat on, or use them to prop up the ends of objects. No idea if this will work.
Cheers.
