Crack in the resin spill shield(same spot as other users), tank window unglued resin spils on the miror. Clean as per instructions, FAIL print after print. Played with Z axis but no luck
Did someone else experienced this after cleaning up?
Have you been in touch with our support team? It can be challenge to remove resin from the mirror and sometimes a replacement is necessary. It sounds like you’ve done a bit of troubleshooting by tuning the Z axis and cleaning the mirror and our support team is going to best suited to assist further.
Yes, i’m talking with support. The mirror is perfectly clean no stains checked with flaslight. Got a decent print after several failures.
