Hi all,
I’m testing different methods of post processing clear 3D printed parts to make them optically clear, in particular spin coating and resin dipping. Briefly, I apply a coating and then put it in the Form Cure v1 for at least 30 minutes without heat. Regardless of the coating technique, the coating comes out sticky/tacky and yellowed. I’ve tested cure times up to 4 hours and the result is the same. I’ve also tested 100 microliter drops of resin in small plastic dishes with the same result.
Another forum member noted the same thing, but the stickiness issue was not addressed in the discussion. The 3D Printed Lenses article doesn’t mention it either.
Do I simply need to cure for longer times? Should I be curing in an inert atmosphere, as I’ve read elsewhere?
Printer: Form 3+, Resin: Clear Resin v4.1
Thanks!
Edit: I also came across this post: Uncured Resin Clear Coating Not Curing
If the sun works, but not the Form Cure v1, then I wonder whether 405 nm light is specifically the problem and whether shorter wavelengths could work.
Since you aren’t getting the initial curing power from the laser during printing, I am not certain if the resin will ever cure quite the way you want it to when coating. Yellowness of the base part will increase with UV exposure as well which you will also be fighting. I’d look into other coating options (coating epoxies - check out some laminated carbon fiber coating forums) or sanding.
Try curing it under water. Oxygen inhibits curing and the water will displace oxygen at the surface helping reducing tack.
Thank you @barreax2 and @leonhart88 .
After some thought I think you’re both likely right. The Form 3+ scans a focused a laser beam on the bottom surface of the resin tank so that localized curing occurs rapidly, under high laser irradiance, and in an oxygen-free environment. This is basically the complete opposite of what happens in the Form Cure.
I’ll try the water trick, as well as irradiation by some UV laser sources that I have on hand. I just don’t understand how Formlabs got the technique in the 3D printed camera article to work since it doesn’t mention either of these.
Maybe the Clear Resin formula has changed since it was published such that it was once possible to dip and cure lenses, but isnno longer possible?
