Clear resin Resolution
Hi it seems that i have trouble printing with the clear resin as the prints always get broken halfway or do not print at at. I have tried cleaning the resin tank but i suspect that the problem may be in the layer thickness . it seems that the smallest resoultion for a clear resin is 50 microns . Can anyone please advise?
Hmm, can you upload some images of your failures and an example of your orientation so that we can help to troubleshoot? There could be a few causes here and images will help us to diagnose.
Clear Resin has options for 100, 50, and 25 micron layers. You should be able to adjust this using the layer thickness slider. Let me know if this isn’t the case for you.
