# BioMed Clear warping during cure
**URL:** <https://forum.formlabs.com/t/biomed-clear-warping-during-cure/44328>\
**Created:** [May 6, 2025, 7:10pm UTC](https://forum.formlabs.com/t/biomed-clear-warping-during-cure/44328 "2025-05-06T19:10:44Z")\
**Showing post:** 3
**Author:** ![MattRForerunner](https://sea1.discourse-cdn.com/flex025/user_avatar/forum.formlabs.com/mattrforerunner/32/20355_2.png) [@MattRForerunner](https://forum.formlabs.com/u/MattRForerunner)\
**Post date:** [May 8, 2025, 8:28pm UTC](https://forum.formlabs.com/t/biomed-clear-warping-during-cure/44328/3 "2025-05-08T20:28:40Z")
> [@Print warping/deforming issues](https://forum.formlabs.com/t/print-warping-deforming-issues/43818/13):
> So previously i described creating supports for a part that had issues warping and removing them at a later time to avoid warping well here is a example as i dont think people quite understood
So We do this for parts we are having issues with warping during post processing and then we remove the supports after curing I would make sure you’re following the wash steps and not letting them absorb to much IPA also like @jessbuck said wait at least 30 mins or longer then cure if your able to clamp the part to something to keep it flat while cooling you can also do that. Just somethings we’ve had success with
_[View the full topic](https://forum.formlabs.com/t/biomed-clear-warping-during-cure/44328)._
