#316
Is the layer shifting now a problem of early form3 printer or have this issue the complete serie??? I have a early form 3 and also the problem with the layers??
What did the support mean to this problem?? can they fix the problem with the many updates in last time??
Thank you for your answers!!
#317
The problems that were present that got me to start this thread in the first place are still present an o updates to date have fixed it. It seems the updates to the black resin have eliminated most of the original issue but all other resins still suffer the same problems.
#318
Hi everybody!
I looked at my first print and… saw all my grids are look damaged. Which reason can it be?
The second question. I reduced walls thickness to 0,3 mm. Is it too thin? Shall I choose lower temperature for Form Cure? I have selected 60 degree.
May be I have washed too long (13 minutes 70% concentrated IPA in the Form Wash… )
Or wrong placed on the platform… I don´t know…
#319
Looks like damage from too-long IPA exposure. IPA is very hard on features that are long and very thin, like your grills.
Recommend trying 7 minute wash in 90% IPA.
Hope this helps.
#320
Form 3 black V4 at 50 microns is working much better for me than Form 3 gray V4 at any resolution including 100 microns.
Form 3 print quality with black V4 at 50 microns is as good as Form 2 print quality in gray V4 at 50 microns. Form 3 black models are sellable in this quality.
But will my customers buy black models? So far, customers prefer gray for easier painting.
Still hoping for a fix to gray V4.
#321
Today new version of preform/firmware was released noting grey resin improvements. Can you check it on your models?
#322
Thank you Stephen
Ok. I will try 7 minutes wash in 90% IPA.
I thought if a take 70% IPA, I can wash little bit longer as by Formlabs recommended… (10 minutes for black V4, 90% IPA). But it looks having not the same result…
Another phenomenon: there are very fine accuracy details on the roof. The handle on the picture has a diameter only 0,3 mm. It is much more accuracy than in Z-direction…
#323
I was having a lot of failures (around a 72% success rate), and on most of those failures the raft would either incompletely adhere to the platform, or the first several layers of the raft would be on the platform, but then about where the lip of the raft would start, it would just cut off, and all subsequent layers would be stuck to the bottom of the tank.I eventually had a set of parts that just wouldn’t print at all, no matter what I did. I was talking about it on the forum, and someone from Formlabs urged me to call support. When I did, they swapped out my machine.
My original machine was from the first batch of orders, pretty much ordered as soon as they announced the machine. The new machine is not having the same problem, and is so far running at an 85% success rate, with most of those failures coming from one difficult part I finally got printing correctly with some work.
There’s not much to see, but this is what one of my failures would look like in clear resin.
#324
I just finished a test of rings with new firmware and update form software- grey V4 looks MUCH MUCH better then any other result I got in the past.
#325
Just printed off a WW2 Russian howitzer with the latest PreForm software upgrade. Printer is the Form 3, with Gray v4 resin at 25um layers setting. Here is the user-visible surface of the model. The base is 30mm x 30mm, just to give you a sense of scale for this 1/285 model. The details are excellent, bearing in mind that a standing figure is only 6-7mm tall:
Here is the top surface, nearest the build platform. You can see the scalloping effect of extra curing between the support connection points. Not an issue for my models but would still be an issue for others:
Robert
#326
I might be wrong - but I think what you see on the bottom is not over curing- was your model parallel to the build platform? Is so- you should angle it slightly and that will prevent this situation along with adding more support
#327
‘Over curing’ was just my interpretation of previous reviews of the potential cause for this phenomenon. Happy to be corrected on the terminology as this is a specialised area. The top surface issues are not a problem from my perspective but thank you for the reminder about angling. I think the bigger issue is that, for some prints at least - for example where there is no surface that is out of view to users, any problems of this nature with the top surface rendering will continue to affect the quality of the prints.
Robert
#328
This is due to the peel forces that “pull” on the thin first layer when it is parallel to the build surface. The support touch points do not pull because the supports are much more resistant to the peeling forces. These slowly equalize from layer to layer and the surface eventually becomes flat. Hence the “pillow button” effect.
Note that this effect is a lot more pronounced on the form 2 ( higher peel forces ) and is one of the main reasons why the Form 3 can get along with smaller touch points.
The solution is to tilt the part.
#329
@lmlloyd - very interesting post. Similar to your experience, late last year, I had an early Form 3 that did not fully print models. It would only print the rafts. The rest of the model was just a thin wafer stuck to the bottom of the resin tank with other debris swimming about the resin. This required wafer removal and resin filtering after each of the first three prints I attempted and a call for help from Formlabs. Removing the wafers stuck to the tank damaged the tank. Formlabs quickly swapped that machine out and replaced the tank, too.
The replacement machine does not have that problem. It sounds like Formlabs was able to correct whatever was going wrong with our early machines.
New tech is high adventure.
The problem I am presently experiencing with the Form 3 printing in black V4 is that it takes a considerably greater force to remove black models from the build platform than gray V4 models. So much more force is required to remove a model from the platform that I am breaking 1 out of every 3 models trying to free them.
This has been talked about in other threads.
I’ll be contacting FL support. Hopefully there is a fix.
#330
See my post in the other thread - but i don’t have the same adhesion issues if you sand and clean the build plate well between builds and also specifically use side cutters & the metal spatula to get parts off.
#331
What grit?
#332
400 or 600 grit works well for me without taking forever. Just make sure you clean it really well afterwards to remove aluminum particulates.
Even if I don’t do this - I always clean the build plate with generous amounts of IPA and several paper towels to remove residual resin. I have a pretty OCD process, but it seems to be working really well.
#333
Very helpful information about adjusting wash times and about prepping the build plate, thank you.
Some more pictures of the latest build - Grey v4 at 25 microns:
Some tidy up still needed, as you can see with the remnants of supports around the base edges, but I am very pleased with the print.
Robert
#334
Hi Alexander. Your orientation is wrong. I’m also making model railways (with form2) and I’ve experimented with orientation a lot to get best results. My first attempts were as your here. You should tilt locomotive to 30-45 degrees to the platform. That will result in supports on the front (or back) of the locomotive but it just cant be avoided because otherwise you get really big surfaces parallel to build plate and they get all messed up while peeling off. This way your print surface will be minimized and with that chances of layers peeling off or getting garbled are getting lower.
Grills like the ones you’ve circled won’t print good ever if every single one of them isn’t supported. Even if they print they’ll get messed up either by IPA or agitation of IPA so I advise you to make them from etched metal (I use service from https://www.etchworks.eu/). If that is not an option print them as relief. I know that doesn’t look the best but it is better than this surely.
Here is how I orient my models:
#335
Here is further proof of the improvement with Grey resin from the last PreForm software update. @larsenstephen provided a sample file that I printed before and after the update. The first photo shows the two prints, both at 25 microns:
There has been a very significant reduction in layer shifts. Closer inspection shows that the issue with the port holes is still not quite right - there is still a flattening of the top of the circular holes. The following photo is a close up of a second print at 50 microns:
Still some tweaks needed but kudos to the FormLabs team for making such a big improvement.
Robert
