HI! so what one should do after finishing a print with the left over resin? Just left it on the tank and cover the tank with the black plastic cover?
Thanks!
Thanks!
exactly - if the print is good, and there’s no chunks on the tank bottom.
just before you print again, gently scape the bottom all over and get the resin all mixed back together again.
if the print fails, you’ll want to strain the resin out into a clean container through a conical paint filter and a funnel. then remove any crap in the tank, wipe it out with IPA and let that dry before refilling.
This topic was automatically closed after 14 days. New replies are no longer allowed.
