Replacement of lens set or Galvo system to produce thinner laser of focus much less than 300 micron. I think there are demands in getting smaller features such as jewelry or miniature.
If you really need to print small parts then consider also buying this (http://www.nanoscribe.de/) It looks like it could make some small features for you. Be sure to order that high powered microscope too.
**To explore the possibility of Form 1, I would compare with other SLA machine such as ****Viper Si2 with the following spec. **
Build layer capability (z-axis): Minimum - 0.02 mm (0.001 inch)
Typical - 0.05 mm (0.004 inch)
Beam (diameter @ 1/e 2 ) Standard mode - 0.250 +/- 0.025 mm (0.010 +/- 0.001 in)
HR mode - 0.075 +/- 0.015 mm (0.0030 +/- 0.0005 in)
This is what I would love to see
