Right at this moment I am printing the butterfly but can already see that there is nothing attached to the build platform. What could be went wrong? Is this a known problem? What can I try to solve it?
Marcus
Marcus
Marcus
If you give us some more information on what the troubles were before you started printing the butterflies it may help. Can we make some assumptions?
The vat is either new or confirmed clear (not clouded and no remaining failed print bits or goo are present).
The resin in the vat is new.
There were minimal or no air bubble present in the resin before you started printing.
The mirrors look clear of debris / dust.
All the fine tuning settings are at the defaults.
That should be a good starting point.
David
