Hello
I have a repeatable issue with my Form 3 printer (newest firmware, occured occasionally).
Whenever I start a print, either uploaded from PreForm or choosen from the printed jobs list, it stucks always for hours in step 3/5 Filling.
The only workaround is to switch off the printer and to choose the aborted job from print jobs.
It does not work when I abort the job, it must be the switch off variant.
This is really annoying and costs a lot of time. It did not occure at the beginning, I expect it’s an issue from the last firmware updates. Resin tank is full.
It sounds like your cartridges empty and you need a new one. Preform reports the amount of resin the can be used rather than how much is left in the cartridge.
Hi all
I have noticed that this only happens with the gray resin.
I changed the tank and cardridge recently and everything worked as usual, no timeout etc.
Is there any issue with the resin level sensor?
If so, why isn’t there a timeout?
Hello community
I have installed the new firmware today and started a new print with gray resin. It seems to work, there was no need for interruption as before.
