Hi Monger,
From what i see your laser “may” be defective but i don’t think so … What i’m saying is, i had a lot of different printers from the start of the kickstarter campaign and i always do a spot test everytime i received a new/ repair unit .
Almost all my printers had the little rabbit ears even when my printer are working perfectly well. I don’t think it’s definite argument for a defective unit.
Maybe because the rabbit shape are not necessarily powerful enough to cure the resin. ( i think it must be taken case by case )
If you seeing a problem in a specific area ( apparently on the hinge side, it’s definitely a mirror problem ) You should look at the small and galvo mirror.
KevinHolmes, this is a great video ! But I’m confident the little spot will disappear if you use a magnet, open the cover and do the same thing. ( curious to see the result … )
